1 - 8 of 8 Posts
They will fit, but I think you either need spacers or to grind the caliper down. I'm not sure which though.
I have spacers cause i needed them with my 20s not sure how big though
They will NOT fit, without grinding the calipers a LOT, and relocating your sway bar, and lca mounts...
I already tried. (with the 6.5" backspacing.
Your rear camber will be WAAAAAY off man.
it needs 6.5-7" backspace.
they will sit like this
Just like the 99-04 wheels do on our cars, they stick out and screw up the treadwear.
the insides of your tires will be gone QUICK
thanks modern muscle...were did u get ur rims amd mt slicks from
I got em offa a buddy with an 04 cobra, with 2 passes on them.
They were supposed to be 05+ bullitts, but I think they were offa bullitt.
But I only made a few passes on them, and the inside was down considerably, and you could literally see then angling in.
the ones in the pic are the previous owners.
no clue as to where they came from.
1 - 8 of 8 Posts
