1 - 7 of 7 Posts
Im finally getting ready to fire my new motor up and have a few questions. First, im getting ready to prime my oiling system. I got an old distributor and cleaned it up and pulled the gear off. Now which way do I need to spin it in order to prime it, clockwise or counter clockwise? Will a cordless drill work?
Also after finally bolting my MAC longtubes up I noticed the steering shaft rag joint comes in contact with one of the primaries. I dont want to pull the header off and dent it, due to them being such a pain to bolt back up. This will be the last time I buy used MACs as they warped, making them really difficult to bolt up. Is there an aftermarket steering shaft that I can get that will allow them to clear? Which one do you recommend?
Thanks:cool:
Most people learn their lesson the first time with Mac products, a cordless drill should work and what kind of shaft would you expect to get?
Some steering shafts say they will clear because they eliminate the bulky rag joint. I just wanted wanted to see if anyone else has used them, before I go out and spend the money, and it still doesnt clear.
Also do I spin it clockwise/counter clockwise?
Steering Shafts - Manual and Power Racks - '79-'04 Ford Mustang
"79-93 Steering Shaft for power steering:
Steering shaft with (2) needle bearing universal joints. Eliminates the rag joint for more header clearance and more precise steering. Fits o.e. power rack. does not fit manual rack."
Im sure they would have been alright if I bought them new, but since they were used Im sure they warped. It took probably 2 hours just to get them bolted up.
Im still not sure which way Im going to go, the shaft is a little under 200 so its not that bad. Im just not into pulling the header off and beating on it with a hammer. It just seems like a ******* way of fixing the problem, when a purchasing another shaft will eliminate the problem and save me the headache.
Anyone have any experience with the steeda steering shaft?
1 - 7 of 7 Posts
