41 - 53 of 53 Posts
Just an fyi for the mustang non-believers...I have personally raced BONE stock ls1's at the track and in the 1/8 they run consistent 8.7's here in TX. Thats where Im at and I dont even have upper/lower c/a, alluminum flywheel and d/s that can still be done that will improve et's and most def be faster than a mere 8.7 (once again in the 1/8th...its all we have..so its all can compare to)
So a bolted up mustang gt against a crappy driver bone stock lsanything..is def possible :yes
But you got 4.10 gears, which are worth more to your ET than any of the other mods that you say that you lack. OP doesn't have 4.10's... Again, something is starting to stink.
Discussion Starter #42
got 3.90s is that close enough?
Discussion Starter #43
But you got 4.10 gears, which are worth more to your ET than any of the other mods that you say that you lack. OP doesn't have 4.10's... C.
MFJ, since u dont believe me and am totaly focused on dismissing all of my honest question about the cars and why this is happening. Here is some proof.
I do infact have 3.90s
Here is the GPS of my friends crappy WS6 on the last open airstrip runs, top speed check it, man does his WS6 suck for speed...
if you are still so convinced that "things are starting to stink" please dont keep on me for this... My OP had a reason, I was trying to figure something out that didnt make sense to me.... So please if u have any usefull info, by all means, but if u still need more proof or am a non-believer, leave this tread be man, I am just trying to find my answer.... No hard feelings man MFJ...
You never mentioned the gears. That would make the difference...
:no Thats not necessarily true
you take away my 4.10's and give me stock gearing again and give me the upper and lower c/a with the alluminum d/s & f/w and I would def run faster than if I just had gears. I dont want to argue with you but clear that up. Let the suspension guys chime in if you dont believe me but its true...people forget how much drivetrain and suspension mods do for our cars :yes
I disagree. A set of sticky tires and some steep gears will net you a lot more than just suspension mods on an underpowered 2v. There have been plenty of stock suspension stangs in the tens.
eehh there have been stock mustang in the tens but thats not the same as what your saying.....Your saying that gears and tires will outdo the gain you would get with the susp mods I mentioned and thats just not the truth. There have been stock stangs in the very high 12's and low 13's with just suspension/ drivetrain mods, show me which gear and tire combo will do that?
Discussion Starter #52
Cedsks, nice to know what my numbers must be ;)
Yea, I had a nice little pull on you that first time, pretty even second time, thanks for the support, BTW to get back on the OT, got any ideas?
I was in 3rd the first time lol. As to ideas, I dint think theirs anything hidden. My motor has been torn apart and it's the stock intervals including cams and we have similar bolt ons.
41 - 53 of 53 Posts
