1 - 6 of 6 Posts
Newbie!!!!
Somewhere in my front end is a squeak. Its when the suspension travels, any little bump or hump in the road it squeaks. You can actually push down on the fender and make it squeak. Very, very annoying!! Any thoughts on where to start looking?
spring isolators
Watch n learn
Likely a bad ball joint or tie rod end, get it fixes ASAP as if it breaks it will be very, very bad. Have someone bounce it and feel the parts with your hand, you should be able to feel the noise.
Exhaust fume addict
May just be able to grease the ball joint or tie rod end if it has a fitting
1 - 6 of 6 Posts
