1 - 3 of 3 Posts
Ok, so about a week ago I brought up an issue I was having with my Manual 04 GT. At 65 mph and above, the car develops a vibration in the driveline. It's mostly felt in the gear shift and ass of the seat. I've had the tires rebalanced, checks for belt separation and bent rims. I've also unbolted the driveshaft from the pinion flange, rotated 180 degrees and reattached with no luck. Today I've replaced the rear u-joint (the front input shaft and u-joint are new) and still the problem persists. Is it possible I could've bent/twisted the actual driveshaft itself and if so, would a vibration come on like a switch?! It's getting frustrating. Also the car has 3.73's for a few thousand miles now with no problems. Please help. :sorry
1 - 3 of 3 Posts
