1 - 7 of 7 Posts
if i try to shift too fast, i grind 2nd, is this a synchro issue?
it only grinds for half a sec and goes in... depends on how hard i slam it.
harder slam = less grind obviously.
yes mine does the same thing most likely synchro issue, im building a new trans to put in mine, the harder i slam mine though the harder it grinds
oh. i just slam it hard enough so it doesnt have much time to grind.
since i have to shift slower, my 1st-2nd shift, i prerev before popping it.
only for that shift though.
oh ok i get it, yes mine just grinds for a milisecond going into second fast
is this bad for it? o_O lol. cause my reverse is gone, and ill be getting it repaired when tax returns come in..
wondering if a rebuild kit will eliminate this.
yes its bad for it, i try to make sure to shift slow to second and avoid it if at all possible, and if you rebuild your trans youll fix everything if you do it right or have it done
just go first to third...lol
either a bent shift fork or a worn synchro
1 - 7 of 7 Posts
