1 - 13 of 13 Posts
ok so 2 days ago when i brake i get these weird grinding noise and when i am just rolling forward slowly it always makes it
its like a grinding like almost sounds like hydralics when air releases but then it sounds like grinding 2 plates together it is coming from the right rear tire
tonight i jacked up the back tire and rotated the tire and it just made the noise the noise whenever i turned the tire
what do you think is wrong is it something with the drum brake or what???? i'm kind of scared when i reversed out of my driveway it was doing it real bad
**** i guess i wont drive it until the shop opens monday
how come this would just happen suddenly?
do you think im safe to make it to the shop?
Sounds like a Sping or the cable broke. It is a Easy fix.
Take the drum off off both sides and take a peak to see what is changed.
Spring kit is 19.00 at Napa
Good Luck
i realized what this noise is
sometimes when i would put my car in park it would not lock in park and would still be able to roll back and make the same exact grinding noise it is now making in drive and reverse
does anyone know what this can be? is it the transmission brake for when i put the car into park?
Discussion Starter · #11 ·
just dropped it off hopefully my trans isnt ****ed but i dont think it is i think its the drums
hopefully its under warrenty since they just redid them when i crashed in october...
Discussion Starter · #12 ·
yep guys the back right tire was metal to metal as suspected
i drove around like this for 2 days could this have caused more damage or pretty much its going to be the same to fix
1 - 13 of 13 Posts
