1 - 3 of 3 Posts
I have a 95 v6 5 speed. Whenever i try to start my car it will start but after it start it makes a weird grinding noise for a second. My guess is that it is the solenoid stiking or something and grinding the pinion gear against flywheel. Also sometime it will just makes a noise...like the pinion gear isnt even engagin. Im certain its the starter but you never know...any thoguhts?
MM's Resident Ricer
get a new starter, sounds like its over winding a good way to eat your flywheel
either shim the starter or you'll be buying a new one and a flywheel.good luck
1 - 3 of 3 Posts
