1 - 12 of 12 Posts
Has to do with making the fuel gauge work correctly IIRC
KILLER
i think the pumps are the same, the sender is different.
NEVER ENOUGH!
I think so not really wanting to run a bop rather just do it right now saleen 3.4 pulley 39lb injectors and buildin a stroker as we speak wont be till spring tho with livin in Illinois
MoM Fanatic
Ill talk with him tonight and see if he would want to sell it. We went to a return fuel cell when we put the boss 302r motor in it
Here is a brand new fuel setup that is much cheaper than the GT500 kit. They have other options, but if you are on the stock shortblock this would be enough fuel for ya. They also have pump and injector packages. I included the text from the ad just incase you aren't a member over there. Definetly a site worth joining.
WWW.S197FORUM.COM
S&H Stage 1 600hp returnless fuel system
Perfect for guys looking to run 500rwhp or less on the stock block with room to upgrade in the future. This setup will support around 600rwhp depending on injectors size without a bap and is a fraction of the cost of the frpp gt500 system. Kit features a modifed GT hat with a walbro 405 pump which flows 440lph @ 13.5 volts/39psi! Also includes my fuel system wire upgrade kit which runs 10 gauge wire with relay to the fpdm to support the bigger pump. The fuel hat is is a direct swap drop in and the wire kit comes with color installation instruction for a clean and easy install. Best value fuel kit you can buy for your S197!
Full setup is $325 with free shipping in the cont us.
*Have your own fuel hat for me to work on or have a spare you want to send me? Send me the hat and the kit is $275 including return shipping to you.
*The fuel level sender resistance reading changed in 2010 so please specify wether you need an 05-09 or a 10 style sender.
*Add $20 if you would like the pprv valve deleted off the hat with this kit.
*Requires custom tuning.
They have a lot of these kit out already and haven't heard of one complaint with them.
1 - 12 of 12 Posts
