1 - 7 of 7 Posts
So im trying to take off my UDP's and put stock ones back on. When i went to go remove the inner bolt it just spins the crank. How am i supposed to get that off> Impact gun?????
honestly i cant remember. my first my was my steeda UDP but i remember it was BITCH to do. my brother and i both had a struggle with it.
we did have to use a pully puller kit to get it off. i thought the stock one was all 1 piece?
Several options.
1. a chain or strap wrench on the crank pulley.
2. a screwdriver or pry bar wedged into the ring gear. There is a rubber cover on the drivers side of the bell housing.
3. On the OEM pulley you may be able to insert a pry bar into it.
4. an impact tool.
Impact... I had to use a high torque impact from a mechanic as my little $75 cheapo wouldn't even zing that bolt off :( Best of luck!
1 - 7 of 7 Posts
