1 - 4 of 4 Posts
We use a better kit that has more to it. it is only $2495 free shipping
It really is a nice kit with everything you need to install and use. Easy to install.
The kit includes the following components:
Frame Reforcement Plate Kit
Flattened Shock Mounting Towers
Custom TCI Dropped IFS Spindles
Steel Inner Fender Panel Kit
Jig Welded Crossmember
TCI Coil-Over Shocks with Adjustable Spring Tension
Black Powder Coated Springs
Urethane Bushed Tubular Upper and Lower A-Arms
11" Disc Brakes With OEM GM Calipers
Power or Manual Rack and Pinion Steering
Steering Tie Rod Ends and Extensions
FREE SWAY BAR KIT
FREE ADJUSTABLE SMALL BLOCK ENGINE MOUNTS
Full Detailed Instruction Manual With Pictures and Descriptions at every step.
Plus, The Rotors, Spindles and Brake units come pre-assembled with bearings packed with High-Temp Grease!
1 - 4 of 4 Posts
