1 - 13 of 13 Posts
I'd like to see how accurate it is. If it's accurate that'd be pretty cool. Do you know if it's able to save the highest numbers? Obviously if you're on a road course you're not going to be looking at the gauge to see what kind of Gs you're pulling so it'd be worthless if it didn't save the highest. For example most boost gauges save the peak boost since you've cleared it. I'd imagine it'd be like that as well. I'd make sure though before I spent the money. Where were you planning on putting it? I've thought about putting another gauge in the vent pod if I ever needed another spot.
according to autometer, it saves the highest everything.
my setup will be like this:
-SOS 3-gauge pillar setup with fuel pressure, oil pressure and trans temp
-Saleen Extreme dual gauge pod (Boost and AIT)
-taking out two center AC vents, installing wideband a/f gauge in driver side middle and this D-PIC gauge in the passenger center...
so both digital gauges in the middle and everything else as said...should look sick
I had to cut a small slit in the back of the pod for the boost line to come up through. When you take out the vent theres a space there to pull your line/wires. I just droped a peice of string down through the vent holes and hauled my line and wires from the floor, its a snap;)
1 - 13 of 13 Posts
