1 - 1 of 1 Posts
Have you seen our awesome deals on Blueprint engines?
http://fortesparts.com/inde…/product/blue-print-engines-306/
http://fortesparts.com/inde…/product/blue-print-engines-347/
306 and 347 packages available, call with questions!
Both packages include:
Blueprint long block
Harmonic balancer
Mini starter
Coil & bracket
302 ignition
M12259 M301 black 9MM wire set
Autolite 3924 Spark Plugs
Breakin Oil Roller Cam
302 Stealth Intake Manifold
Intake Gaskets, Bolts & Studs
Quick Fuel Slayer 600 CFM VS
Fuel Pump SB Ford
Small Block Ford Steel & Filter
Ford 90 Degree H2O Outlet
Thermostat, Gasket, Bypass hose and clamps
Water pump
100 amp Alternator, Bracket & pulleys
Clutch Kit
Fork 5.0 Mustang
Flywheel, Clutch bolts & Pilot
Bellhousing Kit
Cobra air cleaner kit
Cobra valve covers
T-5/TKO-600 (Depends on package)
Machine Tail housing Boss N/C
Assembled to turn-key
Dyno Break-in and video
Fortes Parts Connection
40 Pearl St,
Framingham, MA
508-875-0016
Follow Us on Twitter:
https://twitter.com/FortesParts
Follow us on Instagram:
https://www.instagram.com/fortespartsconnection/
Check out our inventory:
http://www.fortesparts.com/
Youtube Channel:
https://www.youtube.com/user/fortesparts
Sign up for our newsletter:
http://fortesparts.com/#newsletter
If we have sold you a part or built you an engine let us know how we did, drop a comment or send us a message!
We love to hear from you!
1 - 1 of 1 Posts
