Anyone know the name or part# for the stepped headbolts to use 1/2 heads on a 5.0? thanx.
JBIGBOOTSY · Registered Joined Aug 2, 2006 · 4,424 Posts Discussion Starter • #1 • Mar 5, 2008 Anyone know the name or part# for the stepped headbolts to use 1/2 heads on a 5.0? thanx.
R rodthrower2.3T · Registered Joined Sep 10, 2007 · 148 Posts #2 • Mar 5, 2008 (Edited) 7/16 head bolt with stepped shoulder/washers for 1/2 heads Part# 154-3605 = has stepped washers and 12 pt and stepped shoulder Part# 254-3708 both arp part numbers about 130 a set had to change sig pic, tired of looking at TC
T trueblue01 · Registered Joined Feb 11, 2008 · 698 Posts #3 • Mar 5, 2008 At summit arp-200-8598 for washers only, 2 kits required @ $40+ each. Complete bolt / washer kit arp-154-3605 @$92 1 kit required = no brainer.
T trueblue01 · Registered Joined Feb 11, 2008 · 698 Posts #4 • Mar 5, 2008 Sorry for the duplicate info, rodthrower2.3t must type faster than I do.......
1slo5.0 · Premium Member Joined Jan 5, 2006 · 11,367 Posts #5 • Mar 5, 2008 Trick Flow Specialties TFS-51400419 - Trick Flow Head Bolt Bushings - summitracing.com
JBIGBOOTSY · Registered Joined Aug 2, 2006 · 4,424 Posts Discussion Starter • #6 • Mar 5, 2008 bless you all.
