how can i tell the difference in each side of heads.. im at my install portion, and cant remember which head goes on which side.. Does it matter? if so, how can i tell?
as he said about the smog holesheres the thing,.. both sides have identical holes
yes i realize this but if you try to put the head on the other side of the block with the smog holes facing the back of the car its not gunna fit it will only fit with the holes facing forward so its kinda obvious which head goes on which side gotta use your brain sometimes with this stuffas he said about the smog holes
If you look on the side of the head where your power steering and alternator bolt on to the head there will be a cap in the head with threads on the inside of it. On the smog side there will be no cap just threads. That’s how it was on my 5.0 so I am just putting my 2 cents in.how can i tell the difference in each side of heads.. im at my install portion, and cant remember which head goes on which side.. Does it matter? if so, how can i tell?
