1 - 8 of 8 Posts
600RWHP would be as far s I would be willing to take set of TTY bolts. How much are you planning on making?
I only have a built short block with stock everything else (motor wise)and for now am only gonna be at 13psi after I get my suspension I'll bump it up to reach 600 hopefully I can achieve that power with stock heads And different intake
You wont make 600RWHP on stock heads without the help of a GOOD set of cams intake and exaust.
Well perfect I'll run these bolts and gaskets and since my goal is 600-650 after I change heads and cams I'll get some cosmetics and arp studs. How much hp can I make on these heads and intake?
Thanks
I wouldnt say much more then 500-525 RWHP on stock heads and Cams IF your running some serious boost.
1 - 8 of 8 Posts
