1 - 11 of 11 Posts
1 Wheel Peel
Which gaskets do you guys prefer to use?
I just blew mine:tomato
Also on top of that I know most will say P&P the head but I do not have that much money nor time to do it right now... So would it be a good idea to shave the heads a little for higher compression?
I'm looking in the same area.. I think i just blew mine.....
for the second time......
In 3 months......
I want to get some good ones this time.. :)
Im thinking of looking at AM..
the ford mls gaskets with copper spray is what I like to use...
if your pulling the heads, have them ported & polished ;)
Just Cheesin'
Get head studs... If you shave you heads though, you might need shorter pushrods. Unless it's a small enough amount (less than .010") for the lifter to compensate. But the drop in compression would be minimal compared to what it would cost to mill them. The money would be better spent on porting.. You might go from 9.8:1 to 9.9:1.
ford MLS and copper spray like ESG said
i just got mine from tousley ford, they were like $42 each
IIRC ad another "E" to the part number in that pic for the other side
1 - 11 of 11 Posts
