1 - 7 of 7 Posts
I will be installing my new tfs 170 heads but I am unsure of what kind of head gasket to use. It is a stock block. And what kind of arp head bolts/ studs would be best
I'm a MLS gasket fan. Can't go wrong and no need to tear down and redo if you boost or spray it down the road. And head studs are better than head bolts if that's what you were asking.
thanks guys. Summit has a lot of head studs which do you recommend? Most of them say that they are for the preformer heads on the description. Will those work?
i posted the link
<------running tf 170s with above mentioned crap
1 - 7 of 7 Posts
