1 - 4 of 4 Posts
I put on my heads and started to bolt down my intake when i realized there is a coolant hole in the heads and intake that isn't in the 1262 gasket i am matching them to. What do i do? cut it out, leave it, does it even matter?
are u sure it goes all the way into the intake and heads?? if cooland flows through there u shouldnt block it off..
In the back of the heads? Don't worry about it because your intake doesn't have a rear coolant crossover, that is why the gasket isn't cut for it.
thanks darrell i knew one side was blocked off but i couldnt remember if it was the front or the back..
1 - 4 of 4 Posts
