the header is hitting the sterring shaft. put new motor mounts and and it hits just a tad to notice it virbrating my steering shaft. any ideas wat to do to solve this annoying problem? thanks
go under the dash and loosen the 2 bolts thaconnect the steering shaft to the steering wheel. twist the steering wheel to the right and have a friend tighted the two bolts. thats what i did and it worked perfectly. no problems.
omg listen, take the biggest impact socket u can find and slowly tap the header were it hits, i say slowly tap it that way you dont have to dent it more than needed
the bigger the socket the less of a sudden pinch it is
Or you can shim the motor mount on that side like 1/10th inch. It may be that your motor mounts are worn out in the first place causing the engine to sit a little lower than it should.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Modded Mustang Forums
