1 - 13 of 13 Posts
fired up the car last night after putting a 750 holley dp on her.. and after a couple of minutes the headers were glowing red... the fuel pressure is 8.5 psi, its a 351w, D00E heads, Offy 360 intake, crane fireball 2 cam, hei conversion, ... whats the deal? vaccum leak?
Usually glowing headers are an indication of running rich. Unburnt fuel is igniting in the primary tubes causing them to get too hot.
Let me revise that, its retarded timing that couses the unburnt fuel in the primaries to ignite. and yes, extreme lean conditions can do it too.
Ok one more time... I've been reading up on this one.. Glowing at idle can mean rich, because of what I've stated before, meaning, retarded timing.. Glowing while under load, means lean.
I had this happen to me two weeks ago and once I advanced the timing 14-15* the headers no longer got red, my 2cents
Timing....timing....timing.
theres no cats on the car, bbk shortys, h-pipe- 40 series dumps,
its glowing red at idle, we checked the fuel pressure before and it was 12 psi.. so we turned it down to 8.5 psi.. but still glowing red. next is timing.. thanks guys ill keep ya posted.
Thats definately a timing issue. I would even say bring your fuel pressure down to 7.5psi (atleast thats where most carb manufactures reccomend it to be).
you should just leave it.......that just means the engine is crazy mean
lmao...
1 - 13 of 13 Posts
