1 - 15 of 15 Posts
ok... I know that i want to supercharge my car at some point. how usefull would it be to get ported heads and a camshaft?
muneris pro ego
it would be very useful with forces induction. i would advise getting them all done at the same time so the camshaft grind will be a good match with your FI application
do you think i should take their advice a go to a stage 3? i REALLY don't want to spend $2700 on this.
MM's official Chevy guy
first off SSM is over priced
second if you do go FI go at least stage 3 but i would do it at the same time, IMO no mater what stage 2 is a waste.
MM's Resident Ricer
if your going FI go stange 3
muneris pro ego
get stage 3.. if you want engine work done like that and forged pistons (definitely needed for FI) then talk to itschristorres8. you might can get all those for cheaper than SSMS
just in general it will
usually with a turbo most common cause for turbo guys to blow a motor will be a blown piston ring(usually #6)
for a s/c guy it'll usually be something else internal, like a rod or bearing.
but now the s/c is going to have the power and more of a turbo hes getting all the risk
Discussion Starter #12
so you are saying i should also get forged internals?
Discussion Starter #15
ok, thanks.
1 - 15 of 15 Posts
