1 - 5 of 5 Posts
ok i have a 2002 gt order some custom grind crower cams like a stage 2 but i wanted them just a lil bit bigger, had my heads ported to the max to match the header and the typhoon intake. have 75mm tb and upper plenum, also had the intake ported and everything. what should i dyno at after they get put on and everything? anybody with heads and stage 2 cams let me know what they made to the wheel.. i wanna hit 300 to the wheel:D.......
mm's nitrous mod
c&l maf, udp's, and if youre not there i would be suprised. actually i would be suprised if you arent there after head and cam install.
ok so what does your gt have besides spray? and what size shot?
mm's nitrous mod
click my user name and go check out my garage. almost all my mods are there, have stuff just installed and on the way:rockon! i am spraying 125 as of right now.
1 - 5 of 5 Posts
