1 - 20 of 58 Posts
I have heard 2 different stories on heating your springs.. whats the real story.. in my mind.. it would temper the metal and make it softer... therefore make them compress easier which would help traction... i need all the input i can get cuz im thinking about heating my springs to get my car lower and i would rather spend money on something else rather than springs right now so... what is the deal
just cut your springs, you dont want to soften them, they will ride liek ****, and not handle good, you want shorter, and stiffer, not softer.
cars typically sit lower in the front than in the rear.
i would start by chopping 3/4 coil off of it all the way around, then keep cutting 1/4 coil from there until you have it where you want it.
you will however need to get a set of aftermarket CC plates to correct yoru alignment, theres not enough adjustment room int he stockers for lowering it that much.
piss on all that.. ill just wait and get a lowering kit.. lol.. and what i meant by lower in the front as in its lower in front than stock. but rear is stock height... i was told it had a 1.5" eibach lowering kit.. but i dunno... i just want it to be really low to give my wheels a more offset look....
Resident Bubblehead
if you want to ruin your springs, go ahead and heat them up. cutting the springs won't **** them up or make the ride or handling shitty. i helped my buddy cut his on his 04 Cobra, and it doesn't ride bad at all. he cut 3/4 coil off the front and 1 coil off the back, i think. looks lowered about 2 inches...
+1, doesnt change the ride one bit cutting them.
the only time you get in a little bit of trouble is when you cut progressive springs. you take some of the ride quality they give you out. but we've cut springs before on old cars never one problem. other than if you do it too far ball joints start breakin. we've heated them just too see whatll happen. they do good for a little while and then eventually they all become a diff length rate and etc.
1 - 20 of 58 Posts
