1 - 10 of 10 Posts
hello! I am trying to change the heater core on my 70 coupe with air what a pain by the way. ok i have most of the dash out all loose but not all the way out. i hope i can get it this way i have it pulled away on passanger side. so i see the one bolt on the top inside and a few on the outside to get the box loose is that what i need to do is pull the box out of the car or do i leave the box bolted in an take off the bottom of the heater box?
thank you Tom
That is the expansion valve, the little line is the temp sensor line.
The bulb is the reader. It is a pressure switch. It is what make the A/C work.
AIR CONDITIONER EXPANSION VALVE
You should come put one in my '69 when you're done!
i would just love to ,but my list of things is so long i dont have time
lol i suppose when the tires get hot they radiant heat into the car. lol we need the heater a few times a year. I have a new 347 and T 5 sitting on the stand next to the car just running out of time after we eat i am going out to work on getting heater box out all new seals on the way as mustangone suggested
almost done, heater box and dash back in. e brake fixed, t5 in going out now to finish up a few small things, clean up and if i have time see if can get ac recharged. :)
1 - 10 of 10 Posts
