If I dont replace the heater core and hose right away will it do damage to the car?
NO, as long as you bypass the heater core on the engine side of the firewall you will not have any problems.If I dont replace the heater core and hose right away will it do damage to the car?
I never had an issue getting enough heat due to the full exhaust. Lots of heat through the firewall and floor. When my heater core went, I had alot of issues with my defrost fogging the car up worse than it cleared it. And the air smelled a little funny with the antifreeze being piped into the vents.
Thanks for the insight. I may have to wait to replace it. I am low on funds. I have had to replace the engine, radiator, brakes and filler neck in the past three weeks.
