1 - 3 of 3 Posts
i got a quetion for all of those that have bypassed their heaters. what did you do with theoutput on the water pump and the intake. I capped them off with rubber caps and they keep poping and spewing coolant all over. and pics would be awesome . not sure if the heater core is good or not it wasnt hooked up when i got the car. any advise would be great thanks.
u dont cap the waterpump... u put a hose between the two hoses that go to the heater core..i would suggest replacing the heater core...
that would explain them keep popping i had seen someone cap them and it worked for them i am not even sure if the heater core is bad guess i should hook it up and see does it matter which hose goes to which line on the heater core?
1 - 3 of 3 Posts
