Is this not possible with our mustangs. I mean my feet can not fit in that little area where the gas peddle is. when i down shift i usually just throw it into neutral and rev it up and then down shift but heel toe is so much quicker and less annoying. I also noticed our Peddles do not all line up with each other so you can not really put your heel way down in that little area. But if they were all lined up i think i could do it.
Tell me if this will work or will this throw the throttle off and stuff.
That Little screw that is circled in yellow is holding the gas peddle on. It looks like you can adjust it so if you push the lever back farther and then put some sort of stopper on it the gas peddle will be aliened with all the other peddles. This is really hard to explain over the internet so bare with me. Another way of looking at it is if you are sitting in your driver seat and you put your toe under the gas peddle and pull your leg towards you, the gas peddle will move up and be alined with the other peddles but as soon as you take your toe out from under it, it will go back to its normal position . So if i put some kind of stopper on that screw or lever at the top where it is circled in yellow will this throw off the throttle or should i still be able to accelerate like normal?
I want to get to a race track one of these days and heel toe is pretty much something you would need to be able to do.
