1 - 4 of 4 Posts
Hi,
I have recently purchased a 2006 GT convertible with 42K and after a couple of weeks in my possession I have found that the top goes down intermittently. That is I can always power it up but it might go down the first time I try and back up but then when I try to repeat a few minutes later it will not go back down. It always goes back up (I can hear the motor turning if I press the up switch even when it is in the latched up position. I have narrowed it down to the switch or the mini relay #31. Has anyone had similar issues? If so have you replaced the switch and how tricky is it? It is no trouble to replace the relay if necessary.
I should note that when the top does not go down neither do the windows. This leads me to believe it may be the switch. Finally I have yet to switch the up and down mini relays; I will do so when the top stalls again in the down mode.
Thanks for the help!
Eric
First, Welcome. I see this is your first post. I've not had any issues with my top..I know you were asking for anyone that has. Yeah if the windows don't all go down...might be the switch?? Have warranty on it? :)
1 - 4 of 4 Posts
