1 - 6 of 6 Posts
ok guys so my car has been running like a dream for a long time now but last night i pulled in my drive way and my car sounds like its camming. Soon after i get a check engine light. For a while now i have had the code p0174 bank 2 too lean. Havent been able to fix it yet but i believe the problem lies in my tune from sct. Also i installed an o/r h pipe about 4 days ago the car ran great i just put the front 02's in the spots and screwed them in and the rear i just screwed those into the bungs that were for the rear 02's. now grant it one of my front 02 holes were stripped out a bit so i took it to the shop and had them weld in a new bung slightly lower than the one that was originally located on it. Anyways now my car is throwing codes p1131 p1132 and it runs like ass. i took it to advanced and erased the codes and now the car runs normal. i know its only a matter of time before they come back. Any idea guys???? please help! this never happened until i recently put on my h pipe.
Rollin' 18/ pushin' 2
You need to seal off the original bung first if you haven't already. Then you need to install a set of MIL's onto the rear O2 sensors to trick the computer into thinking you still have cats on the car.
thats already been done my sct tuner shut off the rear 02's and the first bung was capped and welded shut. i did out it on the scanner today and the bank 2 sensor is reading 0.0 voltage.
your correct new sensor fixed it
1 - 6 of 6 Posts
