ok well got everything set up and im almost done putting on the new steering shaft and its waaaay too long. is that normal or am I supposed to cut it shorter ive just had enough with all of this
well ive looked onfamling rivers site for about 30minutes now im thinking i just cut the shaft to the length I need. I dont see how else it would work wish me luck!
so what do i do then i dont get it i thought this was supposed to just all bolt together and match up? the shaft kit i have is just 2 u joints and a shaft to connect them with a smaller shaft with a hole in it for the bolt that was removed.
mine isnt the collapseable no springs just a steel shaft im thinking im supposed to cut it to length though theres no way i can get it to fit. i shouldve just gone to a shop and paid but i like to do it myself lol got the car aligned and everything and i cant get the steering shaft on again. So if it looks like the dd shaft i can cut it to length correct?
THANKS i figured that was the case but i like to double check. What is the best tool to cut this thing with ive got a sawz all with a few metal cutting blades what did you use?
thanks man for the info i will get to it tomorrow hopefully ill be driving this car again tomorrow evening how far did you have the first u joint seated on the rack all the way or a gap at the bottom. When im done im taking a few pics theres no pics of this set-up anywhere for reference
its was raining like crazy today so i couldnt. but saturday im doing a eibachpro kit suspension so ill make time for the steering shaft that day too should be fun.
i wish i had a video when i saw it didnt fit i thought it was supposed to join together and be good its all good ill keep everyone posted. did you guys just use regular red lock tite or should i get something different
1 - 14 of 14 Posts
