You can reuse the ECM, and you can re-use the harness with some modifications. You will need a new tune for it though. Depending on how much they quote you for a reflash a new ECM may be cheaper than a tune.youll need to swap in a new harness and a computer...the idle,air fuel mixture is different, along with other parameters of the engine
