1 - 3 of 3 Posts
i know this is in the wrong section but i need help.... so my friend has a 3000gt and he just had a performance clutch put in. when he pushes the pedal in half way it fully disengages but when he pushes it down all the way it slightly engages and starts to slowly move what gives???
Watch n learn
3000gt would be a hydraulic clutch. Most likely a bad clutch master but cold also be a bad slave, I'd start with the master though. Since the clutch is new it may have not been bled properly, kinda tough to bleed, best way I've found is to hold the clutch fork all the way down while bleeding.
1 - 3 of 3 Posts
