1 - 8 of 8 Posts
hello i no my powersteering is leaking and added stop leak fluid a month ago,and the probelm and noise went away.Well now the car is humming badly but the resivoir is still full..so what should i do or check for ...rep will be given I usaully can fix problem with ur guys advice thanks
Discussion Starter #2
double threads web acting gay
I Poop Entirely Way Too Much
Pump might have been damaged whne you lost fluid previously.
is this something that i can lag on fixing or shuld i get changed asap i never had powersteering issuses before with any car
Its hard to tell without hearing the sound but if its got fluids thats what I would lean towards. If it dies you just wont have power steering. Itll be a bitch to turn but you can do it.
something you need to do. The powersteering pump pressurizes your brake system too. No power steering pump, no power brakes.
I Have A FLATULENT Butthole.
Who uses brakes anyway... queers :eek:
it hums real loud when the steering wheel is turned at a certian angle....but the problem was gone last 20 minute drive but im sure the problem will come back...rep for all
1 - 8 of 8 Posts
