1 - 15 of 15 Posts
· Registered
My 2002 coupe with barely 80k miles has recently started creaking when i apply the breaks at low speeds(under 15mph) and when parking/ sitting still and creaks even louder when i let off the breaks. The noise can be heard from inside the car but its louders near the two front wheels. It shoulds as if it is comming from the pedal to wear the breaks are applyed, not the breakpads or anything. Breaking is fine but the sound is anoying. Anyone know what the issue is or how to solve it? thanks
· King of Clubhouse
New pads maybe rotors?
Pull the wheel off have a look, see how they look if you dont know post a pic we all have to learn!!
btw its brakes =P lol just givin ya a hard time 80k id say its time for brakes though
· Registered
the breaks have been replace before but i dont think its the pads or rotors
· Registered
creaking, no high pitch **** squeaking or anything, its a creak it sounds like its comming from whatever the break pedal connects to next. its like grrr when i apply yhe breaks then a lighter grrrrr rrrr when i left off
· Registered
but drawn out
· Registered
it could be the pins on your calipers. they get dry. I dont know if they make noise. If you need to replace your brakes you should check out these articles they are helpfull. Replacing Worn Out Brake Calipers | Tooldesk Automotive Tool Blog , Changing Brake Pads | Tooldesk Automotive Tool Blog. And as far as the cable goes the brakes are hydraulic. It could be the master cylinder is shot and from the sound of that it sounds almost like your brakes may need to be bled cuz it sounds like there is play. Is there play? if so and you want to bleed them Bleeding Your Brakes | Tooldesk Automotive Tool Blog
· Registered
play meaning? they work fine , 100% its only the anoying noise
· Registered
ok well i guess play is a bad word for it i mean spongy feel? Ok so i listened to the video again. Hmm. Where does it sound like it is coming from? Like the floor? It may be the pedal then. If not hmm.... idk. you have any more info? Like more precise where the sound is coming from? I can see how that is annoying.
· Registered
Discussion Starter · #11 ·
nah, they feel just like before , it started liek 2 weeks ago
· Registered
ok. well is the sound from the floor or outside the vehicle?
· Registered
Discussion Starter · #13 ·
sounds like right from the pedal but it can be heard louder outside the vehicle like inside the wheel wells
· Registered
ok well i would have to say that it has to be something outside the vehicle then. Umm it could be wheel bearings maybe. They might be bad. I would recommend taking a tire off and lookin at the brakes and then move the spindles to see if they have lots of play or the wheel bearings are bad.
· MM's Official Lucifer
Its gonna take looking at it all. Get the wheel off on the side you think its comin from. Make sure the rotor isn't warped, pads are still good, etc. Spray some Disc Brake Quiet on the pads since you'll be that far in anyway. If your rotor(s) have started to groove at all it could make noise.
1 - 15 of 15 Posts
