1 - 1 of 1 Posts
Hello, looking for some help with the front struts. Mainly the issue is with the bump stops. According to maximum motorsports website these have bump stops on them. So I really just need some clarification. For some reason when my mm caster camber plates where install they didn't put the bump stops in on the stock strut. So I have found some MM bumpstops from a local person. Do I just slide the mm bumps stop onto the strut, or do I need to get the stock bumpstop off of the stock dustcover and use it with the mm bumpstops on the new koni's? Also should I be ok riding on the stock dustcover and stock bump stop until I get the MM bumpstops? Thanks for any advice that you can give.
Link to the struts-
Koni Package, STR.T Struts & Shocks, 1994-04, solid axle [KONI-9] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
1 - 1 of 1 Posts
