1 - 10 of 10 Posts
needs more boost
Can anyone tell me if this can/is worth fixing? With the amount of rust i'd probably be better off getting a new vehicle but I really can't afford it right now. Really appreciate any advice you guys can give me!
Just driving down the road the other night and this happened lol
Got anymore pictures of the underside?
I know quite a few people on wranglerforum.com have threads about YJ/TJ rust repair. That would be a good place to start.
needs more boost
I'll try to get some more pics tomorrow. I went to wrangler forum.com first and looked through some threads but whenever I went to register it wouldn't let me so I ended up coming back here lol
That's odd it wouldn't let you register. For rust on these though I believe they even make weld in kits to fix a lot of the common area problems. I am not 100% though on that.
That tj isn't long for this world lol. you've got a couple of options.
they make these: Auto Rust Rear Trailing Arm Mounts Frame Repair Kit - Right Side - ART-124R
you're going to have a couple hours cutting and welding but it is a legitimate repair for that issue. the problem is, if that corner looks like that, then there's probably a lot of other places as well. and the body mounts on the tub (just from that pic) look like they're on their way too. if that's the case you're going to keep fighting a losing battle with rust... i see your fenders are gone too which is pretty typical.
i'm guessing that's a 4 cylinder? usually a 4 cyl with a rotten frame will bring a grand or so... assuming you have like, 140k miles, if you fix that frame you should be able to get 2500-3500 or so for it.
oh, your other option is a frame swap. places like D A V E Y S J E E P S . C O M - Specializing in Jeeps & Jeep Parts can sell you a clean frame and the swap really isn't that bad. it took me about 4 days to do the one i did. the front clip comes off in an hour. the tub lifts off with everything attached to it... problem is if your tub is rotten... then why even bother ya know...
What year/miles/trans/motor is the jeep?
---------- Post added at 12:59 PM ---------- Previous post was at 12:57 PM ----------
also, jeepforum.com is a better resource than wranglerforum.
or Pirate4x4.Com - The largest off roading website in the world. but only post in the non-hardcore jeep section.
needs more boost
^ How much do you think it'd cost to fix it? If I could get $3500 for it that would be amazing. Honestly at this point I just want to get it paid off and sell it lol It's a 1997 with 150k miles, 5 speed, and like you guessed it's a 4cyl.
well assuming just that one side is junk you're looking at $250 in materials. if you can't weld then you need to find a shop to do it. i'd guess another $500 but it really depends on the shop and if they're afraid of it or not.
without seeing it i can't say. if there's other areas of rot on the frame you're probably better off to walk away or go get a clean frame and do a frame swap.
i did a frame swap with a buddy of mine and it took us a solid weekend. grabbed the impact gun and started zipping the thing apart. it really wasn't that bad. I think he had 400 bucks into a really nice frame. and maybe 50 bucks in new bolts.
that'd be what i'd do if i decided to keep it. also just FYI, you'll need a 4 cyl frame unless you want to get into cutting and welding new mounts. the 6 and 4 cyl mounts are in different locations and are welded in from the factory.
needs more boost
Discussion Starter #10
^ I'm just getting a new car lol how much if anything would you say it's worth in it's current condition?
1 - 10 of 10 Posts
