1 - 5 of 5 Posts
zippeewannabee
my tuner had taken my computer out to do something on it, and i thought it would be pretty simple to reinstall but cant figure it out.. right now the comp is completely unattached from the kick panel.. does anyone have a diagram of how to install or remove a ecu?
zippeewannabee
Discussion Starter · #2 ·
Anyone? Even just a picture of behind the kick panel just to give me a reference will work
its super easy man, you move the harness out of the way, shove the computer up in the hole behind the kick panel as high up in there as you can and just plug it in
There is like a plastic brace for it, but the computer pretty much sits in a little nook in there. The big harness plugs in the bottom of it and I think an 8 mm bolt holds the harness into the pcm.
zippeewannabee
ok i got it.. i was having a real hard time doing it because ive never done it before and i thought the chip was accessible from the bottom, had a little trouble screwing it down.. the one place we found to run the nitrous line is right behind the comp lol
1 - 5 of 5 Posts
