got the car back from the shop and im a not happy with the results...not as much HP as i expected, and seat of pants increase is not what i expected either...here is the setup
95 5.0 Stock bottom end
AFR 185's, TF Track heat upper and lower, custom comp cam, MSD dizzy and 6al, bbk long tubes, magna flow cat back, c&l 76MM MAF and tube assembly, 30lb injectors, 75mm throttle body,no smog, pulleys, T-5, SCT tune
Items in blue are new items that were just put on. previous dyno pull on same dyno made 203rwhp, and 280 ftlbs of torque
adding items in blue got me 260.2 rwhp, and only 285.14ftlbs of torque
wtf....should have been more....any suggestions?
