1 - 3 of 3 Posts
Finally got to sit down after awhile of late night closings at the part store...Within the next few months after getting my pony to run again i want to take out the 7.5 out and freshen it up and maybe change over on gears.. is there aq rear sway bar i can install on my 7.5 rear end? maybe one that would swap from another car? anyone try this? thanks for the input guys :llama
The sway bar attaches to the lower control arms IIRC, which are the same as the ones on the GTs and all up to '04. I wouldn't bother with putting together a decent 7.5 rear though. If you're going to make enough power to go fast in the first place, you'll want an 8.8 rear. Which is a direct bolt in off of a V8 fox.
The 7.5 is a good rear end to 300-350HP, after that its useless, but if you dont plnan on making morethan that i would use the 7.5 because its lighter.
1 - 3 of 3 Posts
