1 - 3 of 3 Posts
I am not sure, if I should address this thread to something else, but here is my story and I hope someone could help me. I owe 2007 Mustang and today I replaced my bulbs and noticed that my right light wasn't working with High beams on, I checked fuses, everything was fine, I switched bulbs and I got the same problem on both sides, Don't know what happened but my High Beam wires that go to the bulb have no electiricity in them anymore and I switched relay in fuse box for High beams to see if it will fix the problem, but still nothing.
Wax on, Wax off
You said by switching the bulbs you had the same problem on both sides. Did you try using a single bulb in each headlight to see if one of the bulbs was faulty?
Are your old bulbs still in working condition? if so, put them back in and see if the high beams work.
What you need to do here is elminate each varible that you can. First see if its the bulbs. then move on to the wiring and fuses.
1 - 3 of 3 Posts
