I understand that you at least need a return style system to make big power but what about fuel rails and the lines? Is an a1000 setup would be sufficient for 900 hp but any opinions would be appreciated. Thanks.
// WELDON RACING PUMPS // 1400 HP Fuel Pump -- Weldon Racing PumpMaximum HP: (-12 inlet and -10 outlet) 1400 hp Inj @ 14V EFI (700 hp on Methanol) & 1600 hp @ 14V Carb (800 hp on Methanol)
GPH/PSI Range: 140-180 GPH / 0-80 PSI
Considerations: If your actual horsepower is close to the Max HP limit and/or you are considering a power adder, See Part # D2035-A or 2345-A
