1 - 14 of 14 Posts
Baker Jr.
Well I have 4.10s and a procharger...I was wondering what I would have to do so I can somehow stay in 4th and not have to go to 5th..Its going to kill my times...Anyone have expeirence with this, I love the 4.10s on the street with it but i do go to the track sometimes and want to run good times..Besides 3.73s or letting off what could i do..would a 28 inch tire get me by?? Will a 30 fit??
i think you'd have to do a 28" tire. Either that or shift into 5th and coast, you don't wanna blow something up or drop a valve lol.
Baker Jr.
Well before the procharger and just 4.10s and a 26 inch tire i was about 5500 rpm threw the traps
well the procharger won't make you higher in the rpm range for a given speed, but your gears will.
Baker Jr.
I will be running more mph so there for i will have more rpm, everything is the same on the car when i ran a 13.25 and i was at 5500 at the traps, i bolted the procharger on now and im sure i will be hitting 5th near the end cause my 4th gear ends at about 100 i believe. so if i trap 110-115 thats 10-15 mph while in 5th..it will suck
Baker Jr.
Def aint changing the gears, I am doing heads and cams, If I do heads what can I rev it too?? I was never a fan of alot of rpm, just seems to me that its not going anywhere that high..What rpm is the motor safe at
around 6200 if i'm not mistaken. high rev's will kill a stock 4.6 with a blower.
EDIT: and i should have thought about that, for whatever reason it didn't cross my mind.
although the cams/springs/heads do play a big part in rpm capability, your main problem is gonna be the bottom end. it just takes $$ though, with the right parts a 4.6 is capable of quite high rpm's (a guy at out track shift's at 7800 with his fully built 4.6, for example).
Baker Jr.
Discussion Starter · #12 ·
Ya i shift right on red so im consistant, 5700 i believe red line is if im remembering right??? I just dont know if I should sell my new mickeys that ive only used once and get some 28s or 30s
bandity, ive got some 28" slicks that i will sell. They have alot of life left on them. Just throwing that out there. You already want my heads soo....
Baker Jr.
Discussion Starter · #14 ·
Yep i saw you were selling them lol. Im going to the track friday so we will see how bad it is first
1 - 14 of 14 Posts
