1 - 8 of 8 Posts
Ford NTK, Bosch, Denso or other. whats best for leaner or more economical trims. if leaner is meaner what is a better O2?:naughty:
They don't work that way to begin with . They do not make a trim, they simply sweep . the ecu makes the trim based on those sweeps. OEM ford are the most accurate sine wave production.
I only use Ford O2s. And was told this by several ppl in the past. They are supposed to be the best.
they are not built up to tolerance. The results on the oscilloscope are different. Get them OEM or not at all.
^ This .
1 - 8 of 8 Posts
