1 - 3 of 3 Posts
I put a spec clutch in my 04 gt. About 400 miles or so after I noticed a squealing coming from the bell housing. It has 800 miles on it now and the noise is unbearable. Its inconsistent, worse at low speeds, and completely goes away when the car comes to a stop. It doesn't matter if the clutch is engaged or not, in gear or neutral, or the motor is even running. Im baffled. I had the flywheel cut, new clutch, fork, cable, throwout bearing, and I changed the rear main. I cant even drive the car cuz all I wanna do is run it into the trees. Any ideas?
You are going to have to open it up, Spec clutches do not have the best reputation, Google "spec clutch failure", grab a beer or two and start to read...
Spec clutch failures:
Thanks man, I guess. lol. I had pretty much come to that conclusion myself as I've been researching this for a few weeks now. I see your in St Augustine? Im in Middleburg, not too far from you. You guys have any meets or regular hangouts down there?
1 - 3 of 3 Posts
