1 - 2 of 2 Posts
How much HP do you think this combo will make? 57trim T3/[email protected],3in downpipe/exhaust,stinger centermount turbo header,forced 4 CAI,
Bob's sheetmetal intake manifold with 65mm TB,FMIC,the rest of the engine is stock.One more question how much Hp will a Boport stage 2 port and polish with a A-234 cam add?
what size injectors?
if only 35 lb;hrs then your going to max them out at around 300whp
at 16 psi i would say high 260 wheel hp
with that sheet metal intake you cant run a dizzy unless hes changed it
the head isnt going to change much if you leave it at 16 psi and 35lb injectors
but could raise it an easy 50 hp
1 - 2 of 2 Posts
