1 - 20 of 29 Posts
I got a 2007 GT some months back to go along with my 2003 Cobra. Car already had basic bolt ons including LT headers. I'm gonna install the FRPP Hot Rod cams in a month or so, while searching around I wanted to know how much these cams increase the engines redline? Most dyno graphs iv looked at with the FRPP cams show its making peak power a little after 6k rpms. Now I know im entering the danger zone pushing this motor past 6500rpms on the factory valve train and internals, what is the limiting factor to these 3v motor when spinning that high?
First, cams don't increase redlines.
My first tune with FRPP cams had the redline set at 7,000, and I felt that was high. After my build I 7,000 was no issue, and except they robbed boost.
after 7000 rpm if you do not have lockouts i have heard you will have issues with the factory vct causing the pistons to contact the valves.... this is what i have been told anyways
Cams do change where power is made in the RPM band that changes shift points thats what i meant. Those who do after the FRPP cams what rpm are your shift points at?
i wish i could tell you but i just guess i never dynod the car to figure it out
When you go WOT through the gears what rpm do you shift at?
i pull to 6500 but my butt dyno tells me that i am still making power past that at least a lot more then stock where it kinda felt like it fell on its face after like 6300
Resident Headbanger
With the stock valve springs you shouldn't rev the engine past 6800rpm or you risk valve float with possible piston to valve contact. Maximum HP with Hot Rod cams usually comes in at ~6200rpm so you could have the rev limiter raised to 6700rpm.
Discussion Starter #10
Would aftermarket valve springs make it safe to rev to 7000 with factory internals
Resident Headbanger
The answer is yes but it would be rather pointless 'cause the power would be tailing off past 6500rpm anyway. That is, unless you swap out the stock intake manifold for a Ford Racing unit. Then the engine would pull to 7k with ease.
ya i forgot to mention that i have a frpp intake manifold and jlt intake. that along with the cams pushed my power up in the curve and that is why im putting in 4.10s this spring to get me into the power faster
Discussion Starter #13
The answer is yes but it would be rather pointless 'cause the power would be tailing off past 6500rpm anyway. That is, unless you swap out the stock intake manifold for a Ford Racing unit. Then the engine would pull to 7k with ease.[/QUOTE]
That's good to know factory 3v internals can handle the higher rpms car has 4.56s so a higher powerband would be welcome..with the frpp intake manifold since it deletes the CMCVs does the exhaust decel go from smooth to popping?
Blood, Sweat and Gears...
My red-line is at 6800, my cams seem to kick in at about 5,000 to red line. This picture is before I changed my intake.
That's good to know factory 3v internals can handle the higher rpms car has 4.56s so a higher powerband would be welcome..with the frpp intake manifold since it deletes the CMCVs does the exhaust decel go from smooth to popping?[/QUOTE]
i guess it was hard for me to tell if the charge motion deletes made the exhaust poppy but the car does pop a little bit on decel i do know that the manifold and the cams changed the exhaust note a lot
here is a short exhaust clip
https://www.instagram.com/p/BA-qHFBB8VR/?taken-by=bwyss12
My CMDP's were my last mod I did, my exhaust got louder after.
---------- Post added at 06:56 PM ---------- Previous post was at 06:43 PM ----------
If you look close to my dyno sheet you will see some changes that will changed the attitude your Stang.
4000rpm to 5300 rpm above 300 rwtq with stock cams.
3500 rpm to 5500 rpm above 300 rwtq with HotRod cams.
At 6500 rpm 230 rwtq with stock cams and 270 rwtq with HT cams with about more 35 rwhp.
Hot Rod cams are lethal with 4.10's
RAT FINK
The CMDP's change the exhaust quite a bit, I much prefer how mine sounds with them. Idle sounds better, deceleration sounds better. It definitely pops a little more on decel but I like it.
Stock internals will not last long at 7000rpm....although I shift around there as well on occasion (accident). My stepper motor on the tach is sometimes off a bit and I'll hit the 2step rev limit I set at 7050.
Discussion Starter #19
Whats the weakest link with the stock internals? How would the factory oil pump hold up against higher rpms?
1 - 20 of 29 Posts
