1 - 20 of 26 Posts
· Registered
Im looking to burn up my old tires but i dont want to wreck my brakes in the process. My first idea was to somehow disable them but then I got another idea, is there some sort of system or mechanism you can install to turn off the rear brakes at will? Another question I have is, how badly does burning tires mess up your brakes?
· The Despised Vert
new pads = cheap and easy
line locks = much more $$$ and time to install.
your going to have the wheels off any way for the new tire install just slap
some new pads on there
· The Despised Vert
the burn out box really doesn't do as much damage as you would think w/o linelocks... I have made over 300 passes on and my pads in back are still fine... wouldn't be my first choice of a mod... well I guess that's obvious
if he was really going to smoke'em till they pop then the heat might damage the pads but they won't wear out because of one burnout/off
· Registered
Braking systems are biased to the front brakes (most of the car's stopping power is in the front brakes).
So, finding the least amount of brake pressure that will hold the car still and still spin the tires shouldn't hurt your rear brakes much at all. In fact, as long as the car is not moving, it should take less pedal pressure to hold the car still than coming to a stop in normal driving (meaning your rear brakes aren't even working that hard during the burnout).
1 - 20 of 26 Posts
