21 - 26 of 26 Posts
· Registered
Got any pictures of it on your car?
Here's a couple of pictures of the solenoid installed but it's hard to see for all the other stuff in that area.
From another angle...
This where i installed the line lock control in my front cup holder. The kit comes with a basic toggle switch but I decided to go with a momentary push button switch (the red one) instead. Besides using it for burnouts I also use it to hold the car on the line while I run the RPMs up for launching, sort of like with a trans brake but not quite as effecient.
· Registered
· Registered
You could always install the panel and make room for the nitrous switches, or install the switches in advance and hook them up when you install the N2O.
I also installed a rocker switch in my panel to activate the hi speed fan with the ignition off for cooling at the track or between Dyno pulls.
21 - 26 of 26 Posts
