1 - 17 of 17 Posts
how do i find out my gear ratio
if it's stock there's an axle code on either the inside of the door frame, or in the glove box, I don't remember which.
For the 65 (assuming that's what you have from the text under your avatar)
1 = 3.00
3 = 3.20
4 = 3.25
5 = 3.50
6 = 2.80
7 = 3.80
8 = 3.89
9 = 4.11
A = 3.00 t-lock
C = 3.20 t-lock
D = 3.25 t-lock
E = 3.50 t-lock
F = 2.80 t-lock
G = 3.80 t-lock
H = 3.89 t-lock
I = 4.11 t-lock
no the rear end has been changed out to i think a 9" im not sure id have to check that to if i can determine the rear end will this help?
eh, in that case I think the easiest way (other than pulling it apart and counting the teeth) would be to calculate it .. though i'm not sure of the calculation, give me a minute and i'll see if i can't find it
bump so i can find out tomorrow
do the front wheels have to be suspended too???
i have drive up ramps for the front and 2 jack stands for the back would that work?
well the parking brake only applies to the rear, so to be safe, i'd leave the front on the ground, and chalk them, and just raise the back and put it on the jack stands.
Discussion Starter · #11 ·
i dont think so
i dont even know what rear end i have :(
can you tell from these pics???
also what is that stuff leaking down from it :dunno
doesnt look right....
looks like an 8 inch.block front wheels.jack up one wheel in rear.put trans in neutral.turn drive shaft yoke down.mark yoke and houseing in same place.put mark on wheel.rotate shaft and count the times the shaft goes around to one turn of the wheel.now devide that.done
Discussion Starter · #14 ·
i got 1 1/2 rotations of the driveshaft for 1 rotation of the tire......
what ratio is that????
Discussion Starter · #15 ·
1 thing guys....
i had the tire spun while i counted drive shaft rotations
rather than me spinning the shaft and them telling me when 1 tire rotation was complete
does this make a difference?
1 - 17 of 17 Posts
